Maya 2018.6 | Vray Next 4.30.01 | PhoenixFD 4.10 Fatal error
  • Maya 2018.6 | Vray Next 4.30.01 | PhoenixFD 4.10 Fatal error
    I have a curious problem. I installed Vray Next 4.30.01 and latest PhoenixFD 4.10 for Maya 2018 (.6 here).
    When I render a scene without Phoenix stuff in Maya, it renders. When I render a Scene with Phoenix stuff it creates a fatal error // Error: V-Ray : There was a fatal error rendering the scene. //
    If I render the same scene (with phoenix stuff) from the command line (mayabatch), it renders fine.
    The simulation I'm trying to render was simulated with PhoenixFD 4.00. I will try to setup a quick scene from scratch with PhoenixFD 4.10.
    any hints ?
    www.mirage-cg.com
    Hey, can you tell me the exact names of the installers you used for V-Ray and Phoenix?
    Sounds like a bad install for now...
      I did the installation 2 times, with clean uninstall and reboot.
      vray_adv_43001_maya2018_x64.exe
      phoenixFD_adv_41000_maya2018_vray4_x64.exe
      Meanwhile I tried a new scene from scratch, and I have the same fatal error.
      I tried then to install on Maya 2019.2 (vray_adv_43001_maya2019_x64.exe and phoenixFD_adv_41000_maya2019_vray4_x64.exe) and it renders fine.
      www.mirage-cg.com
        Trying it now, I have Maya 2018.5 here, will try it with this one and then update it if I can't reproduce it. Is there anything in the Maya log as it's loading up before you start rendering?
          Meanwhile, can you double check if these files are there and they all have the same timestamp and size:
          C:\Program Files\Autodesk\Maya2018\vray\vrayplugins:
Name:	maya 2018 install 1.jpg
          C:\Program Files\Autodesk\Maya2018\phoenixfd\plug-ins:
Name:	maya 2018 install 2.jpg
            file -f -new;
            // Warning: file: C:/Program Files/Autodesk/Maya2018/scripts/startup/rememberViewportSettings.mel line 29: Active stereo does not work with Aero enabled. Active stereo has been disabled. //
            // untitled //
            commandPort -securityWarning -name commandportDefault;
            // Error: line 1: Could not open command port commandportDefault because that name is in use. //
            isolateSelect -state 1 modelEditor2;
            isolateSelect -loadSelected modelEditor2;
            onSetCurrentLayout "Maya Classic";
            // Warning: V-Ray VolumeGrid: Loading shaders failed - no <*.txt> files in . //
            VRayVolumeGridInit();
            // Initializing V-Ray for Maya
            evalDeferred "shaderBallRendererMenuUpdate";
            // Warning: file: C:\Users\olivier\Documents\maya\2018\prefs\filePat hEditorRegistryPrefs.mel line 4: filePathEditor: Attribute 'aiImage.filename' is invalid or is not designated 'usedAsFilename'. //
            // Warning: file: C:\Users\olivier\Documents\maya\2018\prefs\filePat hEditorRegistryPrefs.mel line 5: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' is invalid or is not designated 'usedAsFilename'. //
            // Warning: file: C:\Users\olivier\Documents\maya\2018\prefs\filePat hEditorRegistryPrefs.mel line 6: filePathEditor: Attribute 'aiStandIn.dso' is invalid or is not designated 'usedAsFilename'. //
            // Warning: file: C:\Users\olivier\Documents\maya\2018\prefs\filePat hEditorRegistryPrefs.mel line 7: filePathEditor: Attribute 'aiVolume.filename' is invalid or is not designated 'usedAsFilename'. //
            # pymel.core : Updating pymel with pre-loaded plugins: invertShape, vrayvolumegrid, vrayformaya, renderSetup, GPUBuiltInDeformer, deformerEvaluator, modelingToolkit
            updateRenderOverride;
            // Error: VRay: Could not load the Bifrost module! You will not be able to render Bifrost as isosurface or metaball. The error message is:[loadLib] LoadLibrary failed (126): The specified module could not be found.
            // AbcExport v1.0 using Alembic 1.7.5 (built Feb 6 2018 18:28:0
            // AbcBullet v1.0 using Alembic 1.7.5 (built Feb 6 2018 18:28:0
            file -f -options "v=0;" -ignoreVersion -typ "mayaBinary" -o "W:/projets/OC_Comete/scenes/Comete_New8_8_14_18knots_200317_FD42.mb";addRecent File("W:/projets/OC_Comete/scenes/Comete_New8_8_14_18knots_200317_FD42.mb", "mayaBinary");
            requires -nodeType "PhoenixFDSimulator" -nodeType "PhoenixFDLiquidSource" -nodeType "PhoenixFDOceanTexture" -nodeType "PhoenixFDPGroup" -nodeType "PhoenixFDFoam" "phoenixfd" "4.10.00";
            # Phoenix Fluid Dynamics ADV for Maya 2018 / V-Ray 4.x, version 4.10.00, Build ID: 20200305
            # Warning: Phoenix FD: Loading shaders failed - no <*.txt> files in . #
            phxfdInit();
            'C:/Program Files/Autodesk/Maya2018/phoenixfd/scripts' added to the python path.
            requires -nodeType "VRaySettingsNode" -nodeType "VRaySunShape" -nodeType "VRaySunTarget" -nodeType "VRayGeoSun" -nodeType "VRayLightDomeShape" -nodeType "VRayMtl" -nodeType "VRayBlendMtl" -nodeType "VRayPlaceEnvTex" -nodeType "VRayPlane" -nodeType "VRayAerialPerspective" -nodeType "VRayRenderElement" -nodeType "VRayGeomList" -dataType "VRaySunParams" -dataType "vrayFloatVectorData" -dataType "vrayFloatVectorData" -dataType "vrayIntData" "vrayformaya" "Next";
            // Warning: line 0: 'time1.outTime' is already connected to 'PhoenixFDOceanTexture1.currentTime'. //
            # Error: You are attempting to load a file that contains legacy render layers into a scene that uses render setup. This combination is unsupported and may result in unexpected behavior. #
            // Warning: line 1273: The default image may not be modified. Use the -i/image flag instead. //
            import maya.app.general.mentalRayNotAvailableDialog as mrnad ; mrnad.show() ; del mrnad
            // Warning: line 0: Errors have occurred while reading this scene that may result in data loss.
            Please check the Script Editor for details. //
            // File read in 2.2 seconds.
            // AbcImport v1.0 using Alembic 1.7.5 (built Feb 6 2018 18:28:0
            updateRendererUI;
            www.mirage-cg.com
              Hmm, nothing fatal in the log....
                Yes, all files are there, same timestamp and same size as what you show
                www.mirage-cg.com
                  Roger that, so can you check C:\Users\ [your-user] \AppData\Local\Temp and see if there are any *dmp files from recent hours/minutes?
                    sorry, no dmp files there
                    www.mirage-cg.com
                      Hmm, I'm out of ideas. Does the crash happen when you create an Ocean preset, sim 1 frame, stop the sim and render?
                        Yes, I tried to sim with ocean preset based on a cube and it makes the same fatal error when you try to render. So, on your workstation with Maya 2018.5 it works well ?
                        But, don't worry. On my side, as it seems to work well on Maya 2019, I think I will switch to these versions for the work.
                        Thanks for your input.
                        www.mirage-cg.com
                          Hmm, could it be that you saved the scene after the Fatal error? What if you make a new scene - does it still show the error?
                          Georgi Zhekov
                          Phoenix Product Manager
                          Chaos
                            I didn't save the scene.
                            - scene 01 (created with Maya 2018 and previous builds from Vray Next and PhoenixFD) doesn't render on Maya 2018.6 but renders fine on Maya 2019.2
                            - scene 02 (created in Maya 2018 from scratch) doesn't render in Maya 2018.6
                            - scene 03 (no phoenixFD stuff) renders fine on Maya 2018.6
                            www.mirage-cg.com
                            • #15
                              Very weird. Indeed I could not reproduce it with 2018.5 or 2018.6...
